When I park my car the car detection will always stay active. Because of the angle and position of the camera detection when it enters a zone will not work for me. I see that the event is in progress, does that mean that the camera is recording even when it is stationary?
Is there any config I can use to stop the event or stop the recording when the car is stationary?
Car is active, has 0 objects and car motion is clear. Camera state is recording and event is in progress. So it seems for me that frigate is still recording even with 0 objects.
The car state does not seem to go clear again. (Same can be said for Person, and other objects that has been detected earlier, but that now are gone)
Might have been a bug, since the car was stationary when I restarted Frigate. This is how it looks 5 min after car is detected. For me it looks like the camera is recording non-stop after.
Any object detection as soon as frigate starts is ignored until there is motion near it so that makes sense.
Careful, you keep saying “recording” but there is a difference between “recording” and “being tracked”.
Whether or not it is being recorded entirely depends on the mode that I linked above. Meanwhile regardless of the mode, Frigate will continue to track that object and the event will show as In Progress
If there is motion between the camera and the car it will trigger an event. You can add an object mask to the area you are parked in to better stop that.
That’s exactly what I explained, and you need to change your recording mode to adjust this recording behavior. It seems like you’re not reading the docs I’m showing as this is clearly explained.
Yeah this can be done and is what I meant by “disabling stationary tracking”. We don’t really recommend it due to the constant event behavior, but it is an option.
I dont see how changing recording mode to active_objects will do the trick, when the car sensor always has one object and active when the car is parked(?)
