tung256
(tung)
October 27, 2021, 6:18pm
1
my Frigate NVR was working fine on Oct 18th. after that it refuses to run.
I pressed Start and it looks like it’s working but nothing
logs show:
my frigate.yml file looks the same. nothing was changed.
did something changed on Frigate’s side?
tmjpugh
(Tmjpugh)
October 27, 2021, 8:35pm
2
Look like you did Not make breaking changes for 0.9.x releases
Look at docs for Breaking changes to Clips and Record
Frigate releases
EDIT
Also look at changes for Detect config. It has moved as well. The detect changes look like cause for your log errors
tung256
(tung)
October 28, 2021, 6:44pm
3
thanks!
looks like i will revert back then.
i dont have time to play around the new settings having a new twin at home.
tmjpugh
(Tmjpugh)
October 28, 2021, 9:04pm
4
It’s not much but yeah(twins)… fully understand
tung256
(tung)
October 29, 2021, 1:45pm
5
OK, upon reading the Log tab of Frigate again, i see it did not like 3 lines of:
fps
width
height
after removing those lines, frigate works as before! not too bad
