Hi all,
My frigate stopped since a few weeks. No recordings, events don’t work etc.
The UI still is showing the camera’s but if I open it or click on events nothing happens.
As far as I know nothing changed so not sure why its not working?
Below password has been changed.
Any help would be appreciated!
I am using 2x Amcrest ad410.
"birdseye": {
"enabled": true,
"height": 720,
"mode": "objects",
"quality": 8,
"width": 1280
"cameras": {
"3A": {
"best_image_timeout": 60,
"birdseye": {
"enabled": true,
"mode": "objects"
"detect": {
"enabled": true,
"fps": 5,
"height": 1920,
"max_disappeared": 25,
"stationary": {
"interval": 0,
"max_frames": {
"default": null,
"objects": {}
"threshold": 50
"width": 2560
"ffmpeg": {
"global_args": [
"-hide_banner",
"-loglevel",
"warning"
"hwaccel_args": [],
"input_args": [
"-avoid_negative_ts",
"make_zero",
"-fflags",
"+genpts+discardcorrupt",
"-rtsp_transport",
"tcp",
"-timeout",
"5000000",
"-use_wallclock_as_timestamps",
"1"
"inputs": [
"global_args": [],
"hwaccel_args": [],
"input_args": [],
"path": "rtsp://admin:[email protected]:554/",
"roles": [
"record",
"rtmp",
"detect"
"output_args": {
"detect": [
"-f",
"rawvideo",
"-pix_fmt",
"yuv420p"
"record": [
"-f",
"segment",
"-segment_time",
"10",
"-segment_format",
"mp4",
"-reset_timestamps",
"1",
"-strftime",
"1",
"-c",
"copy",
"-an"
"rtmp": [
"-c",
"copy",
"-f",
"flv"
"ffmpeg_cmds": [
"cmd": "ffmpeg -hide_banner -loglevel warning -avoid_negative_ts make_zero -fflags +genpts+discardcorrupt -rtsp_transport tcp -timeout 5000000 -use_wallclock_as_timestamps 1 -i rtsp://admin:[email protected]:554/ -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an /tmp/cache/3A-%Y%m%d%H%M%S.mp4 -c copy -f flv rtmp://127.0.0.1/live/3A -r 5 -s 2560x1920 -f rawvideo -pix_fmt yuv420p pipe:",
"roles": [
"record",
"rtmp",
"detect"
"live": {
"height": 720,
"quality": 8
"motion": {
"contour_area": 30,
"delta_alpha": 0.2,
"frame_alpha": 0.2,
"frame_height": 50,
"improve_contrast": false,
"mask": "",
"mqtt_off_delay": 30,
"threshold": 25
"mqtt": {
"bounding_box": true,
"crop": true,
"enabled": true,
"height": 270,
"quality": 70,
"required_zones": [],
"timestamp": true
"name": "3A",
"objects": {
"filters": {
"cat": {
"mask": null,
"max_area": 24000000,
"max_ratio": 24000000,
"min_area": 0,
"min_ratio": 0,
"min_score": 0.5,
"threshold": 0.7
"dog": {
"mask": null,
"min_area": 0,
"min_ratio": 0,
"min_score": 0.5,
"threshold": 0.7
"person": {
"mask": null,
"min_area": 0,
"min_ratio": 0,
"min_score": 0.5,
"threshold": 0.7
"mask": "",
"track": [
"person",
"dog",
"cat"
"record": {
"enabled": true,
"events": {
"objects": null,
"post_capture": 5,
"pre_capture": 5,
"retain": {
"default": 10,
"mode": "motion",
"objects": {}
"expire_interval": 60,
"retain": {
"days": 0,
"mode": "all"
"retain_days": null
"rtmp": {
"enabled": true
"snapshots": {
"clean_copy": true,
"crop": false,
"enabled": true,
"height": null,
"quality": 70,
"retain": {
"default": 10,
"mode": "motion",
"objects": {}
"timestamp": false
"timestamp_style": {
"color": {
"blue": 255,
"green": 255,
"red": 255
"effect": null,
"format": "%m/%d/%Y %H:%M:%S",
"position": "tl",
"thickness": 2
"ui": {
"dashboard": true,
"order": 0
"zones": {}
"3B": {
"birdseye": {
"enabled": true,
"mode": "objects"
"detect": {
"enabled": true,
"fps": 5,
"height": 1920,
"stationary": {
"interval": 0,
"max_frames": {
"default": null,
"objects": {}
"threshold": 50
"width": 2560
"ffmpeg": {
"global_args": [
"-hide_banner",
"-loglevel",
"warning"
"hwaccel_args": [],
"input_args": [
"make_zero",
"-fflags",
"-rtsp_transport",
"tcp",
"-timeout",
"5000000",
"1"
"inputs": [
"global_args": [],
"hwaccel_args": [],
"input_args": [],
"roles": [
"record",
"rtmp",
"detect"
"output_args": {
"detect": [
"-f",
"rawvideo",
"-pix_fmt",
"yuv420p"
"record": [
"-f",
"segment",
"-segment_time",
"10",
"-segment_format",
"mp4",
"1",
"-strftime",
"1",
"-c",
"copy",
"-an"
"rtmp": [
"-c",
"copy",
"-f",
"flv"
"ffmpeg_cmds": [
"cmd": "ffmpeg -hide_banner -loglevel warning -avoid_negative_ts make_zero -fflags +genpts+discardcorrupt -rtsp_transport tcp -timeout 5000000 -use_wallclock_as_timestamps 1 -i rtsp://admin:[email protected]:554/ -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c copy -an /tmp/cache/3B-%Y%m%d%H%M%S.mp4 -c copy -f flv rtmp://127.0.0.1/live/3B -r 5 -s 2560x1920 -f rawvideo -pix_fmt yuv420p pipe:",
"roles": [
"record",
"rtmp",
"detect"
"live": {
"height": 720,
"quality": 8
"motion": {
"contour_area": 30,
"delta_alpha": 0.2,
"frame_alpha": 0.2,
"frame_height": 50,
"mask": "",
"threshold": 25
"mqtt": {
"crop": true,
"enabled": true,
"height": 270,
"quality": 70,
"timestamp": true
"name": "3B",
"objects": {
"filters": {
"cat": {
"mask": null,
"min_area": 0,
"min_ratio": 0,
"min_score": 0.5,
"threshold": 0.7
"dog": {
"mask": null,
"min_area": 0,
"min_ratio": 0,
"min_score": 0.5,
"threshold": 0.7
"person": {
"mask": null,
"min_area": 0,
"min_ratio": 0,
"min_score": 0.5,
"threshold": 0.7
"mask": "",
"track": [
"person",
"dog",
"cat"
"record": {
"enabled": true,
"events": {
"objects": null,
"post_capture": 5,
"pre_capture": 5,
"retain": {
"default": 10,
"mode": "motion",
"objects": {}
"retain": {
"days": 0,
"mode": "all"
"retain_days": null
"rtmp": {
"enabled": true
"snapshots": {
"clean_copy": true,
"crop": false,
"enabled": true,
"height": null,
"quality": 70,
"retain": {
"default": 10,
"mode": "motion",
"objects": {}
"timestamp": false
"color": {
"blue": 255,
"green": 255,
"red": 255
"effect": null,
"position": "tl",
"thickness": 2
"ui": {
"dashboard": true,
"order": 0
"zones": {}
"database": {
"path": "/media/frigate/frigate.db"
"detect": {
"enabled": true,
"fps": 5,
"height": 720,
"max_disappeared": null,
"stationary": {
"interval": 0,
"max_frames": {
"default": null,
"objects": {}
"threshold": null
"width": 1280
"detectors": {
"cpu": {
"device": "usb",
"num_threads": 3,
"type": "cpu"
"environment_vars": {},
"ffmpeg": {
"global_args": [
"-hide_banner",
"-loglevel",
"warning"
"hwaccel_args": [],
"input_args": [
"make_zero",
"-fflags",
"-rtsp_transport",
"tcp",
"-timeout",
"5000000",
"1"
"output_args": {
"detect": [
"-f",
"rawvideo",
"-pix_fmt",
"yuv420p"
"record": [
"-f",
"segment",
"-segment_time",
"10",
"-segment_format",
"mp4",
"1",
"-strftime",
"1",
"-c",
"copy",
"-an"
"rtmp": [
"-c",
"copy",
"-f",
"flv"
"live": {
"height": 720,
"quality": 8
"logger": {
"default": "info",
"logs": {}
"model": {
"height": 320,
"labelmap": {},
"labelmap_path": null,
"path": null,
"width": 320
"motion": null,
"mqtt": {
"client_id": "frigate",
"host": "192.168.178.33",
"password": null,
"port": 1883,
"stats_interval": 60,
"tls_ca_certs": null,
"tls_client_cert": null,
"tls_client_key": null,
"tls_insecure": null,
"topic_prefix": "frigate",
"user": null
"objects": {
"filters": null,
"mask": "",
"track": [
"person"
"plus": {
"enabled": false
"record": {
"enabled": false,
"events": {
"objects": null,
"post_capture": 5,
"pre_capture": 5,
"retain": {
"default": 10,
"mode": "motion",
"objects": {}
"retain": {
"days": 0,
"mode": "all"
"retain_days": null
"rtmp": {
"enabled": true
"snapshots": {
"clean_copy": true,
"crop": false,
"enabled": false,
"height": null,
"quality": 70,
"retain": {
"default": 10,
"mode": "motion",
"objects": {}
"timestamp": false
"color": {
"blue": 255,
"green": 255,
"red": 255
"effect": null,
"position": "tl",
"thickness": 2
"ui": {
"use_experimental": false
