So I added a usb hub. Now I’ve been getting different errors. When I restart frigate it wil run for a few days or a week then I get this again.
[2023-07-06 15:22:52] watchdog.front_right INFO : No frames received from front_right in 20 seconds. Exiting ffmpeg...
[2023-07-06 15:22:52] watchdog.front_right INFO : Waiting for ffmpeg to exit gracefully...
[2023-07-06 15:22:52] frigate.video ERROR : front_right: Unable to read frames from ffmpeg process.
[2023-07-06 15:22:52] frigate.video ERROR : front_right: ffmpeg process is not running. exiting capture thread...
[2023-07-06 15:23:02] watchdog.front_right ERROR : Ffmpeg process crashed unexpectedly for front_right.
[2023-07-06 15:23:02] watchdog.front_right ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88422d40] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88cc9600] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88ceab80] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d0c100] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d2dac0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d4f280] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d70c40] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d92400] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88db3dc0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88cc39c0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88ce7980] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d2c840] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d50bc0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d0fec0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d76b80] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d99180] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88dba940] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88cbf280] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88ccc240] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88d086c0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88ce9700] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88d2f400] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88d533c0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88d76ac0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88d99180] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88422780] [swscaler @ 0x564a88dba940] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88422780] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88cc3680] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d08e80] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88ce98c0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d2f400] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d533c0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d76dc0] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88d99240] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [swscaler @ 0x564a88414f00] [swscaler @ 0x564a88dbac00] deprecated pixel format used, make sure you did set range correctly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : rtsp://admin:[email protected]/Streaming/Channels/102: Connection timed out
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [flv @ 0x564a884425c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962135, current: 658962135; changing to 658962136. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962136, current: 658962136; changing to 658962137. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962154, current: 658962154; changing to 658962155. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962161, current: 658962161; changing to 658962162. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962434, current: 658962434; changing to 658962435. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962435, current: 658962435; changing to 658962436. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962472, current: 658962472; changing to 658962473. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962473, current: 658962473; changing to 658962474. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962474, current: 658962474; changing to 658962475. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962475, current: 658962475; changing to 658962476. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962476, current: 658962476; changing to 658962477. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962477, current: 658962477; changing to 658962478. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962478, current: 658962478; changing to 658962479. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962479, current: 658962479; changing to 658962480. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962480, current: 658962480; changing to 658962481. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962481, current: 658962480; changing to 658962482. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962482, current: 658962481; changing to 658962483. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962483, current: 658962482; changing to 658962484. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962484, current: 658962483; changing to 658962485. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962485, current: 658962484; changing to 658962486. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962486, current: 658962485; changing to 658962487. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962487, current: 658962486; changing to 658962488. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962488, current: 658962486; changing to 658962489. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962489, current: 658962487; changing to 658962490. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962490, current: 658962488; changing to 658962491. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962491, current: 658962489; changing to 658962492. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962492, current: 658962490; changing to 658962493. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962493, current: 658962491; changing to 658962494. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962494, current: 658962492; changing to 658962495. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962495, current: 658962493; changing to 658962496. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962496, current: 658962493; changing to 658962497. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962497, current: 658962494; changing to 658962498. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962498, current: 658962495; changing to 658962499. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962499, current: 658962496; changing to 658962500. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962500, current: 658962497; changing to 658962501. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962501, current: 658962498; changing to 658962502. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962502, current: 658962498; changing to 658962503. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962503, current: 658962499; changing to 658962504. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962504, current: 658962500; changing to 658962505. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962505, current: 658962501; changing to 658962506. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962506, current: 658962502; changing to 658962507. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962507, current: 658962503; changing to 658962508. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962508, current: 658962504; changing to 658962509. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962509, current: 658962505; changing to 658962510. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962510, current: 658962505; changing to 658962511. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962511, current: 658962506; changing to 658962512. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962512, current: 658962507; changing to 658962513. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962513, current: 658962508; changing to 658962514. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962514, current: 658962509; changing to 658962515. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962515, current: 658962510; changing to 658962516. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962516, current: 658962511; changing to 658962517. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962517, current: 658962511; changing to 658962518. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [segment @ 0x564a88444480] Non-monotonous DTS in output stream 0:0; previous: 658962518, current: 658962512; changing to 658962519. This may result in incorrect timestamps in the output file.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [flv @ 0x564a884425c0] Failed to update header with correct duration.
[2023-07-06 15:23:02] ffmpeg.front_right.detect ERROR : [flv @ 0x564a884425c0] Failed to update header with correct filesize.
Again any help greatly appreciated
