Hi All
I’ve got Frigate running in a docker container but I can’t get any streams to decode.
When I navigate to port 5000, the frigate interface loads, but the loading circle never diappears:
My configuration file only has a single camera in (for now) and is a Reolink 510. The stream is coming from an NVR definitely works in VLC (copy&paste) so address, username and password are 100% correct.
Wdith, Height and Frame Rate are all taken from the Reolink software configuration directly (so I assume correct?)
Any thoughts what is wrong with my setup?
mqtt:
host: 192.168.0.206
user: {mosquitto user}
password: {mosquitto password}
cameras:
Garage_cam: # <------ Name the camera
ffmpeg:
inputs:
- path: rtsp://{FRIGATE_RTSP_USER}:{FRIGATE_RTSP_PASSWORD}@192.168.0.58:554//h264Preview_06_main # <----- Update for your camera
roles:
- detect
- rtmp
- record
detect:
width: 2569 # <---- update for your camera's resolution
height: 1920 # <---- update for your camera's resolution
fps: 30
record:
enabled: True
There is a Reolink NVR in the loop with my setup (IP address 192.168.0.58). The actual camera I am trying to access is at 192.168.0.60, but the RTSP stream from the NVR should be fine for what I am doing at the moment. Unless having the NVR in the loop fundamentally changes things for Frigate?
