Frigate UI Question
This is more of a Frigate question than an HA question, but I was wondering if anyone who currently uses the add-on has noticed that after changing the View Order of the cameras it does not change them when on mobile? I changed the order (dragging and dropping) and it works fine on my laptop, but when viewing on mobile they are still out of order, and I do not see a way to change order on mobile.
I also even tried:
ui:
  order: 1
Which I found referenced in an old GitHub post, but does not seem to be documented at all other than using birdseye: order:
Also reset cache after changing, and still no luck.
Thanks, if anyone has any suggestions or can let me know if their cameras follow set order on mobile, so I know if its just my setup or if that’s how it works for everyone.
if you change the order of cameras in the config using
ui:
  order: X
it will affect the default layout on all devices. The camera group layouts are customizable per device and changing on one device will not affect others
