Frigate won't start correctly
My Frigate add on on HaOS just randomly quit working the other day. I can’t get it to load. To my knowledge nothing has changed on home assistant nor did I change any settings or anything. I can’t even get into the web view to get the other configuration logs. I’m new to Frigate, it took me weeks just to get it up and running smoothly and it seemed to be working just fine and then it literally just quit for what I think is no apparent reason.
So from the outside it looks like it’s starting without giving me any errors but I don’t have any camera feeds or anything.
s6-rc: info: service s6rc-fdholder: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service s6rc-fdholder successfully started
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service log-prepare: starting
s6-rc: info: service log-prepare successfully started
s6-rc: info: service nginx-log: starting
s6-rc: info: service go2rtc-log: starting
s6-rc: info: service frigate-log: starting
s6-rc: info: service nginx-log successfully started
s6-rc: info: service go2rtc-log successfully started
s6-rc: info: service go2rtc: starting
s6-rc: info: service frigate-log successfully started
s6-rc: info: service go2rtc successfully started
s6-rc: info: service go2rtc-healthcheck: starting
s6-rc: info: service frigate: starting
s6-rc: info: service go2rtc-healthcheck successfully started
s6-rc: info: service frigate successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
2023-11-16 01:04:54.162110483  [INFO] Preparing go2rtc config...
2023-11-16 01:04:54.163551814  [INFO] Starting Frigate...
2023-11-16 01:04:54.165004807  [INFO] Starting NGINX...
s6-rc: info: service legacy-services successfully started
2023-11-16 01:04:54.203463289  [INFO] Got IP address from supervisor: 10.0.0.91
2023-11-16 01:04:54.235964544  [INFO] Got WebRTC port from supervisor: 8555
2023-11-16 01:04:54.519522927  [INFO] Starting go2rtc...
2023-11-16 01:04:54.596465270  20:04:54.596 INF go2rtc version 1.2.0 linux/amd64
2023-11-16 01:04:54.596746899  20:04:54.596 INF [api] listen addr=:1984
2023-11-16 01:04:54.597099972  20:04:54.597 INF [rtsp] listen addr=:8554
2023-11-16 01:04:54.597440921  20:04:54.597 INF [srtp] listen addr=:8443
2023-11-16 01:04:54.597699353  20:04:54.597 INF [webrtc] listen addr=:8555
2023-11-16 01:04:55.252014017  [2023-11-15 20:04:55] frigate.app                    INFO    : Starting Frigate (0.12.1-367d724)
2023-11-16 01:05:04.164471738  [INFO] Starting go2rtc healthcheck service...
2023-11-16 01:05:07.765702506  2023/11/15 20:05:07 [error] 137#137: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", upstream: "http://127.0.0.1:5001/stats", host: "ccab4aaf-frigate:5000"
2023-11-16 01:05:07.765774956  172.30.32.1 - - [15/Nov/2023:20:05:07 -0500] "GET /api/stats HTTP/1.1" 502 157 "-" "HomeAssistant/2023.11.2 aiohttp/3.8.5 Python/3.11" "-"
2023-11-16 01:05:37.591577373  172.30.32.2 - - [15/Nov/2023:20:05:37 -0500] "GET // HTTP/1.1" 200 6698 "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/hassio" "Mozilla/5.0 (Linux; Android 13; SM-S918U Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/119.0.6045.66 Mobile Safari/537.36" "127.0.0.1, 172.30.32.1"
2023-11-16 01:05:37.908516998  2023/11/15 20:05:37 [error] 138#138: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: , request: "GET /api/config HTTP/1.1", upstream: "http://127.0.0.1:5001/config", host: "sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa", referrer: "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//"
2023-11-16 01:05:37.908560405  172.30.32.2 - - [15/Nov/2023:20:05:37 -0500] "GET /api/config HTTP/1.1" 502 559 "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//" "Mozilla/5.0 (Linux; Android 13; SM-S918U Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/119.0.6045.66 Mobile Safari/537.36" "127.0.0.1, 172.30.32.1"
2023-11-16 01:05:43.275888536  2023/11/15 20:05:43 [error] 138#138: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: , request: "GET /api/config HTTP/1.1", upstream: "http://127.0.0.1:5001/config", host: "sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa", referrer: "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//"
2023-11-16 01:05:43.275979822  172.30.32.2 - - [15/Nov/2023:20:05:43 -0500] "GET /api/config HTTP/1.1" 502 559 "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//" "Mozilla/5.0 (Linux; Android 13; SM-S918U Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/119.0.6045.66 Mobile Safari/537.36" "127.0.0.1, 172.30.32.1"
2023-11-16 01:05:53.493020362  2023/11/15 20:05:53 [error] 138#138: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: , request: "GET /api/config HTTP/1.1", upstream: "http://127.0.0.1:5001/config", host: "sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa", referrer: "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//"
2023-11-16 01:05:53.493086589  172.30.32.2 - - [15/Nov/2023:20:05:53 -0500] "GET /api/config HTTP/1.1" 502 559 "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//" "Mozilla/5.0 (Linux; Android 13; SM-S918U Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/119.0.6045.66 Mobile Safari/537.36" "127.0.0.1, 172.30.32.1"
2023-11-16 01:06:03.258447869  2023/11/15 20:06:03 [error] 138#138: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: , request: "GET /api/config HTTP/1.1", upstream: "http://127.0.0.1:5001/config", host: "sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa", referrer: "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//"
2023-11-16 01:06:03.258532615  172.30.32.2 - - [15/Nov/2023:20:06:03 -0500] "GET /api/config HTTP/1.1" 502 559 "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//" "Mozilla/5.0 (Linux; Android 13; SM-S918U Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/119.0.6045.66 Mobile Safari/537.36" "127.0.0.1, 172.30.32.1"
2023-11-16 01:06:08.487004823  2023/11/15 20:06:08 [error] 138#138: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: , request: "GET /api/config HTTP/1.1", upstream: "http://127.0.0.1:5001/config", host: "sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa", referrer: "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//"
2023-11-16 01:06:08.487062633  172.30.32.2 - - [15/Nov/2023:20:06:08 -0500] "GET /api/config HTTP/1.1" 502 559 "https://sdg8snww45s8wj5wq257owccnr244aul.ui.nabu.casa/api/hassio_ingress/Lf72IINRuovHOSHBMoh8de4se84WSCAjH4qz39YZrgE//" "Mozilla/5.0 (Linux; Android 13; SM-S918U Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/119.0.6045.66 Mobile Safari/537.36" "127.0.0.1, 172.30.32.1"
Logs are indicating frigate has not started yet.
Oh okay, thank you. I’m not very good at reading them obviously. Any ideas on what kind of troubleshooting I can do or what might be happening? It was literally running fine at like a week ago or so and then it just stopped working for what appears to me, no reason…
These are only from a few minutes, it would be good to know what they look like after 10 minutes
I just rebooted my NUC and it magically started working. I should’ve done that first, instead of making a post lol.
#embarrasing
