Frigate won't upgrade
I am trying to update the frigate integration it fails and this is in the supervisor logs
Not sure what to do !
22-10-17 02:57:56 INFO (MainThread) [supervisor.backups.manager] Creating new partial backup with slug e89773b9
22-10-17 02:57:56 INFO (MainThread) [supervisor.backups.manager] Backing up e89773b9 store Add-ons
22-10-17 02:58:22 INFO (SyncWorker_2) [supervisor.docker.addon] Export image ccab4aaf/amd64-addon-frigate-fa to /data/tmp/tmptfcx2vm8/image.tar
22-10-17 02:58:36 INFO (SyncWorker_2) [supervisor.docker.addon] Export image ccab4aaf/amd64-addon-frigate-fa done
22-10-17 02:58:36 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on ccab4aaf_frigate-fa
22-10-17 03:01:52 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
22-10-17 03:01:54 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon ccab4aaf_frigate-fa
22-10-17 03:01:57 INFO (MainThread) [supervisor.backups.manager] Creating partial backup with slug e89773b9 completed
22-10-17 03:01:57 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ccab4aaf/amd64-addon-frigate-fa:3.1 to blakeblackshear/frigate:0.11.1
22-10-17 03:01:57 ERROR (SyncWorker_1) [supervisor.docker.addon] Invalid build environment, can't build this add-on!
22-10-17 03:02:01 INFO (MainThread) [supervisor.api.middleware.security] /snapshots access from cebe7a76_hassio_google_drive_backup
Looks like you are trying to update the addon, not the integration. Please clarify.
If you are talking about the add-on, uninstall, then install the update as mentioned in the release notes.
Thank You - uninstall and reinstall worked :slight_smile:
