Hello, we use the Fritz Dect 301 thermostats. According to AVM, they have a boost mode that can be switched on and off by pressing a button for a long time.
This hvac mode is missing in the view in the developer tools.
Is there any way to integrate this mode into HA?
I think the issue was already solved in OpenHab and the boost function works there now.
Is there a solution for this in HA or must the temperature be set to max. and switched off when the target temperature is reached?
Many thanks
Hy there, im using the Fritz DECT 302 TVR and i habe the same problem.
Having the Boost function would be a great advantage.
Is it possible to listen to events fired from the Fritz Smart Mobile app to integrate them in HA?
I bought a Fritz Dect also and the integration is perfect, but i do not find a possibility to get the info if the boost/freeze-function is on or not. Do you find in the meantime any solution for that problem ?
