I‘m on the latest HA version and would like to get a device_tracker of an iPhone (source of the tracker is the fritz!box integration).
Problem now: the tracker always reports the phone to be away (regardless of how many times I connect or disconnect the phone to WI-FI).
I have not configured a device_tracker in configuration.yaml
and have selected Enable old discovery method
in the fritz!box integration.
So the fritz!box assigns the same IP address to the iPhone, there is an entry in known_devices for that particular phone:
iPhone:
hide_if_away: false
mac: XX:XX:XX:B2:FE:B4
icon: mdi:cellphone
track: true
From the log files I can see a disconnect and connect from the WI-FI.
2022-06-26 06:59:22 DEBUG (SyncWorker_9) [homeassistant.components.fritz.common] Client dev_info: Device(connected=False, connected_to='', connection_type='', ip_address='192.168.178.36', name='iPhone', ssid=None, wan_access=True)
2022-06-26 07:00:00 DEBUG (SyncWorker_0) [homeassistant.components.fritz.common] Client dev_info: Device(connected=True, connected_to='', connection_type='', ip_address='192.168.178.36', name='iPhone', ssid=None, wan_access=True)
Yet the entity itself device_tracker.iphone
always reports Away
