This automation blueprint will make Alexa announce the current caller on the landline.
Requirements:
- Alexa Media custom component for the announcements
- Fritz!Box Callmonitor to get the current caller
Blueprint:
Blueprint, which you can import by using this forum topic URL:
blueprint:
name: Call Notification
description: Send an announcement/tts via Alexa when somebody calls the landline
domain: automation
input:
notify_entities:
name: Entities to notify
description: These must be media_player entities from the alexa_media custom integration.
selector:
entity:
domain: media_player
integration: alexa_media
phone_entity:
description: This sensor must be from the fritzbox_callmonitor integration.
selector:
entity:
#integration: fritzbox_callmonitor
domain: sensor
announcement_switch:
name: Use Announcement instead of TTS
description: Announcements begin with a two-tone melody and will be silence when DnD mode is on. TTS on the other hand will not be impacted by DnD mode and will start immediately without the melody before.
selector:
boolean:
default: false
message_prefix:
description: Message that will be appended before the name of the caller
default: "Incoming call from: "
message_suffix:
description: Message that will be appended after the name of the caller
default: ""
message_unknown:
description: This is the text that will be said when no name is available (supressed or not in address book)
default: "Unknown"
more_action:
description: If you want Home Assistant to do something else, you can define a custom action here. This is optional.
default: []
selector:
variables:
# This is the state of the person when it's in this zone.
announcement_switch: !input announcement_switch
notify_entities: !input notify_entities
phone_entity: !input phone_entity
message_prefix: !input message_prefix
message_suffix: !input message_suffix
message_unknown: !input message_unknown
entity_id: !input phone_entity
platform: state
to: ringing
condition: []
- data_template:
method: all
type: "{% if announcement_switch %}announce{% else %}tts{% endif %}"
message: >
"{% set name = state_attr(phone_entity, 'from_name') %}
{{ message_prefix }} {% if name == "unknown" %}{{ message_unknown }}{% else %}{{
name }}{% endif %} {{ message_suffix }}"
target: "{{ notify_entities.entity_id }}"
service: notify.alexa_media
- choose:
default: !input more_action
mode: single
Comments:
I wanted to implement a way to add an optional action that gets executed after the announcement. I think this should be a default option, but I wasn’t able to execute a custom action after the announcement action. Please let me know if you know a way. This works now! You can add a custom action at the bottom.
Also, I didn’t get default values to work for the text selectors.
