logfile:
Aug 11 11:53:30 raspberrypi hass[21289]: INFO:homeassistant.loader:Loaded device_tracker.fritz from homeassistant.components.device_tracker.fritz
Aug 11 11:53:30 raspberrypi hass[21289]: INFO:homeassistant.util.package:Attempting install of https://github.com/deisi/fritzconnection/archive/b5c14515e1c8e2652b06b6316a7f3913df942841.zip#fritzconnection==0.4.6
Aug 11 11:53:49 raspberrypi hass[21289]: Command “/srv/hass/hass_venv/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-sr8i6_hh/lxml/setup.py’;exec(compile(getattr(tokenize, ‘open’, open)(file).read().replace(’\r\n’, ‘\n’), file, ‘exec’))” install --record /tmp/pip-dj0uxf2m-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/hass/hass_venv/include/site/python3.4/lxml --home=/tmp/tmpdmcy1wa6” failed with error code 1 in /tmp/pip-build-sr8i6_hh/lxml/
Aug 11 11:53:49 raspberrypi hass[21289]: ERROR:homeassistant.bootstrap:Not initializing device_tracker.fritz because could not install dependency https://github.com/deisi/fritzconnection/archive/b5c14515e1c8e2652b06b6316a7f3913df942841.zip#fritzconnection==0.4.6
on my last installation everything works fine. had to reinstall everything because my scared was corrupted. i had a backup of my homeassistant configuration files, so there can’t be any config failures.
any hints ?
TIA: could you change to Topic and add Raspian to it
I have switched over to ubuntu 16.04 and still have the same issue, don’t really want to un install and start from scratch but may have to the issue seems to be a dependence of the package, in my case I believe it’s lxml, trying to install lxml manually fails, will try a reinstall this weekend if I get the time
