Hi, since this morning (and after update of core 2022.3.6) Fritz Box integration is broken.
Is it a known issue? does anyone know how to solve it?
Logger: homeassistant.config_entries
Source: components/fritz/common.py:204
First occurred: 09:01:36 (1 occurrences)
Last logged: 09:01:36
Error setting up entry FRITZ!Box 7530 for fritz
File "/usr/local/lib/python3.9/site-packages/fritzconnection/core/soaper.py", line 140, in raise_fritzconnection_error
root = etree.fromstring(response.content)
File "/usr/local/lib/python3.9/xml/etree/ElementTree.py", line 1347, in XML
parser.feed(text)
xml.etree.ElementTree.ParseError: mismatched tag: line 1, column 156
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 335, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/fritz/__init__.py", line 30, in async_setup_entry
await avm_wrapper.async_setup(entry.options)
File "/usr/src/homeassistant/homeassistant/components/fritz/common.py", line 178, in async_setup
await self.hass.async_add_executor_job(self.setup)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/fritz/common.py", line 204, in setup
info = self.connection.call_action("DeviceInfo:1", "GetInfo")
File "/usr/local/lib/python3.9/site-packages/fritzconnection/core/fritzconnection.py", line 284, in call_action
return self.soaper.execute(service, action_name, arguments)
File "/usr/local/lib/python3.9/site-packages/fritzconnection/core/soaper.py", line 259, in execute
return handle_response(response)
File "/usr/local/lib/python3.9/site-packages/fritzconnection/core/soaper.py", line 241, in handle_response
raise_fritzconnection_error(response)
File "/usr/local/lib/python3.9/site-packages/fritzconnection/core/soaper.py", line 150, in raise_fritzconnection_error
raise FritzConnectionException(msg)
fritzconnection.core.exceptions.FritzConnectionException: Unable to perform operation. 401 Unauthorized (ERR_NONE)401 UnauthorizedERR_NONEWebserver Tue, 22 Mar 2022 08:01:36 GMT
System Health current state
System Health
version: core-2022.3.6
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.9
os_name: Linux
os_version: 5.10.103
arch: x86_64
timezone: Europe/Rome
GitHub API: ok
GitHub Content: ok
GitHub Web: ok
GitHub API Calls Remaining: 4974
Installed Version: 1.23.0
Stage: running
Available Repositories: 1083
Downloaded Repositories: 4
logged_in: true
subscription_expiration: 1 April 2022, 02:00
relayer_connected: true
remote_enabled: true
remote_connected: true
alexa_enabled: false
google_enabled: true
remote_server: eu-central-1-2.ui.nabu.casa
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 7.5
update_channel: stable
supervisor_version: supervisor-2022.03.5
docker_version: 20.10.9
disk_total: 222.8 GB
disk_used: 10.7 GB
healthy: true
supported: true
board: generic-x86-64
supervisor_api: ok
version_api: ok
installed_addons: File editor (5.3.3), Node-RED (11.1.0), ESPHome (2022.3.0), Terminal & SSH (9.3.0), InfluxDB (4.4.0), Samba Backup (5.0.0)
dashboards: 1
resources: 0
mode: storage
