Fritz!box integration - missing connection info after upgrade HA
Hi!
I’ve upgraded from an older version to 2010.10.1 and now my Fritz!box integration won’t report anymore the internet connection informations. It’s 6890 box so suspect this is related to the fact I’m solely using a LTE connection on this device…
Is there any way to get these info back? I’m particularly interested in:
  • connection uptime
  • connection speed (used to be sensor.fritz_box_6890_lte_max_connection_upload_throughput)
  • transferred data up/down (used to be sensor.fritz_box_6890_lte_gb_received)
Second question: is there a simple way to gather ONLY these information and skip device tracking and internet access switch?
Third question: anyone is able to suggest any other way apart from this integration to gather such connection info?
Thanks a lot in advance!
filed a bug here for q1 Fritz!Box Tools integration not reporting connection info anymore · Issue #79814 · home-assistant/core · GitHub
end up in rolling back to 2021.5.1 fritzbox_netmonitor (as a custom integration) and everything work perfectly now
