Fritz!OS 7.57 has an annoying bug which breaks device tracking, specifically in combination with 3rd party Access Points.
The issue is that when a device that is being tracked (like an iphone) connects to the wifi of the Fritz!Box itself, it gets registered a wireless connected device. When the tracked device roams to another (3rd party) Access Point, in older Fritz!OS’s it would get registered as LAN connected. With the new Fritz!OS 7.57 it no longer gets registered as LAN connected but as Idle. Even though you are still connected through the WiFi with the tracked device and everything works on the tracked device, Fritz!Box still says the tracked device is idle.
This issue is also in reverse. When you connect the tracked device first to the 3rd party Access Point it gets registered in the Fritz!Box as LAN connected. When you then roam to the wifi of the Fritz!Box it now becomes idle. In older OS’s it would simply switch to wireless connected.
Work around 1: My 3rd party Access Points are Devolo Magic 2 WiFi. With the Devolo Home Network integration you can do the device tracking with them too. So the tracked devices would remain “home” if they were roaming. However sometimes this would not work smoothly as the tracked device was not updated quick enough and the person would still be shown as “not home”.
Work around 2: don’t use the wifi of the Fritz!Box. So I basically switched off the wifi of the Fritz!Box and bought an extra Access Point (unifi U6-Pro). So all devices now exclusively connect through 3rd party Access Points. This causes (after a restart of the Fritz!Box and some time waiting) all wireless devices to be registered as LAN connected. When you then roam from one 3rd party Access Point to the other it remains LAN connected and doesn’t show as idle.
I first noticed this issue when my Fritz!Box 7490 was temporarily replaced with a newer model for testing purposes. This new model had the new OS installed and right away my device tracking stopped working when roaming through the house. My 7490 did not have the new OS so when I switched back to the 7490 Fritz!Box, the device tracking worked normal again. However a few weeks ago the 7490 was upgraded automatically to OS 7.57 and now behaves the same as the new model Fritz!Boxes.
I am in contact with AVM - the makers of the Fritz!Box, but the issue is very difficult to explain and return e-mails seem to suggest that they themselves do not understand the issue. If more people will complain about the issue, it might get resolved. Till then not using the Fritz!Box wifi has solved the issue.
I can confirm this issue exists, and I have previously reported it to Fritz. They requested, and I sent, several logs from the router for periods when my phone was shown as idle, but it was connected via a Devolo Magic 2 WAP. Like you, I am not convinced they understood the problem. I did not get a satisfactory reply - in the end, they suggested I roll back to an earler version of the firmware (which did not have the bug). I’m afraid I couldn’t be bothered.
I did find an odd workaround, but I don’t know whether it would work for you. The new Fritz firmware includes WPA3 as a security option for WiFi. I set the router up for WPA2 and WPA3. The Devolo WAPs also include WPA3, but I did not enable it, i.e. on my LAN only the router does WPA 3. Now my phone will only connect to the router - it ignores the WAPs. I assume it is going for the highest available security. This does mean that, in some parts of the house, the phone gets a very weak WiFi signal - but then it switches to 4G, so it doesn’t matter as far as the phone is concerned. I have background geolocation turned on on the phone, and that prevents HA from thinking I am Away when I am in the house but the phone goes out of WiFi range (I use Nabu Casa).
This workaround might seem a bit Heath Robinson, but it actually works reliably for me. It has had no negative effects on the rest of my LAN.
It’s a pity if Fritz can’t or won’t fix this bug, but I’m guessing the number of users who will be concerned about it is very small. On the other hand, I have recently seen some Fritz-branded HomePlug devces which look to me very much like re-badged Devolos, so maybe Fritz will suddenly take an interest if people are affected when using “their” WAPs.
Fritz!Box 7530 + Fritz!Repeater 1200 AX (works perfectly) and Draytek 2860 working as an ad hoc wireless AP in an inaccessible part of the house. Would like to see the Vigor’s clients reporting as “connected through LAN2” (as other wired clients also connecting through LAN2 do (Vigor is connected through same switch)). Another 1200 AX due shortly but Vigor will be reprovisioned to connect wired CCTV and would like to retain ability to have wireless outdoors clients reporting their status.
OK, this is a couple of years down the track, so apologies. I run a wifi 6 home network with a Fritz!Box and a couple of access points. The tracking issue is very definitely still not fixed in version 8.n and onward. With wifi enabled on the Fritz!Box, known devices connected through access points (non Fritz AFAIK) show as idle. But the real problem is that after a while, or at first log on, they don’t get the full system resources. It looks like they’re low bandwidth, low capablity (IOT?) devices, even if they’re high-spec computers, and they connect accordingly. I was tearing my hair over why a gigabit NIC on a gigabit wifi link would only connect at 150 mbit (unless bizarrely, I briefly connected to the Fritz!Box). But files transferred locally at gigabit speeds, and upload was gigabit??? And the solution (sort of) just as before, is to turn off the Fritz!Box wifi. Then everything works properly. So, it’s unlikely, but just in case any poor soul has the same issue …
