I have created a gerneric thermostat. The real thermostat is an AVM Fritz!Dect 301. The temperature sensor is a DIY Tasmota sensor, which also works perfectly as a device in HA. The actual temperature from the sensor is displayed in the generic thermostat. However, the real thermostat does not take over any settings from the generic one. I can neither regulate the temperature nor switch the heating on or off. The configuration of the gerneric thermostat looks like this:
climate:
- platform: generic_thermostat
unique_id: thermhedi
heater: climate.hedi01
target_sensor: sensor.tasmota_am2301_temperature
min_temp: 8
max_temp: 26
ac_mode: false
precision: 0.5
target_temp_step: 0.5
comfort_temp: 21
away_temp: 16
sleep_temp: 16
precision: 0.1
The ids of the target_sensor and the heater are absolutely correct.
Has anyone already had experience with this combination and perhaps got it to work?
