Hi together,
I am running two Fritz DECT200 switches via “device_tracker: fritz”, and I get the power consumption and temperature of the included sensors.
Everything is going very well, only the long-term-stats in grafana are “broken”.
For every “normal” sensor I am able to active the “force_update” option, if the sensors are not changing measurements over a long time to get clean status lines. But how to set this option for the fritz DECT sensors, which are automatically usable over the device_tracker plugin, but not defined as single sensor in the config file?
At the moment grafana only shows “changes”, because hass.io is only loggin the changed values, not “every” measured value over the day.
Thanks for help, folks!
Regards,
Dave
