Hey everybody,
First of all, I am pretty new to the whole Home Assistant thing.
I am using HassOS 3.10 on a Raspberry PI 3B and so far it worked out pretty well for me. Now I’m desperately trying to configure the Fritz_Netmonitor Component. I added the following to the configuration.yaml:
- platform: fritzbox_netmonitor
host: 192.168.178.1
But so far, even after restarting the whole Home Assistant multiple times, the netmonitor refuses to show up as a sensor and therefore can not be added to the UI.
Here is the Traceback:
fritzbox_netmonitor: Error on device update!
File "/usr/local/lib/python3.7/site-packages/fritzconnection/core/fritzconnection.py", line 204, in call_action
service = self.device_manager.services[service_name]
KeyError: 'WANCommonIFC1'
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 304, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 461, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 240, in wrapper
result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/fritzbox_netmonitor/sensor.py", line 119, in update
self._is_linked = self._fstatus.is_linked
File "/usr/local/lib/python3.7/site-packages/fritzconnection/lib/fritzstatus.py", line 41, in is_linked
'GetCommonLinkProperties')
File "/usr/local/lib/python3.7/site-packages/fritzconnection/core/fritzconnection.py", line 206, in call_action
raise FritzServiceError(f'unknown service: "{service_name}"')
fritzconnection.core.exceptions.FritzServiceError: unknown service: "WANCommonIFC1"
What can I do?
Greetings,
Colin
