I was trying to user fritzbox_netmonitor
to keep under control the DSL status and the throughput of the line.
So I wrote a piece of configuration to get some parameter from the entity fritz_netmonitor
Unfortunately some sensor look to work someother haven’t any value.
In my configuration dsl_transmission_rete_up/down
show no value (zero) when others looks to works such as external IP.
Attributes of the fritz_netmonitor
indeed are correctly valorized.
Any Idea?
- platform: fritzbox_netmonitor
sensors:
dsl_line_link:
friendly_name: "DSL Line Link"
entity_id: sensor.dsl_line_link
unit_of_measurement: ''
value_template: "{{ state_attr('sensor.fritz_netmonitor', 'is_linked') }}"
dsl_line_status:
friendly_name: "DSL Line Status"
entity_id: sensor.dsl_line_status
value_template: "{{ state_attr('sensor.fritz_netmonitor', 'is_connected') }}"
dsl_external_ip:
friendly_name: "DSL External IP"
entity_id: sensor.dsl_external_ip
value_template: "{{ state_attr('sensor.fritz_netmonitor', 'external_ip') }}"
dsl_router_uptime:
friendly_name: "DSL Router Uptime"
entity_id: sensor.dsl_router_uptime
unit_of_measurement: 's'
value_template: "{{ state_attr('zensor.fritz_netmonitor', 'uptime') }}"
dsl_transmission_rate_up:
friendly_name: "DSL Transmission rate UP"
entity_id: sensor.dsl_transmission_rate_up
unit_of_measurement: 'Mbps'
value_template: "{{ state_attr('sensor.fritz_netmonitor', 'transmission_rate_up') }}"
dsl_transmission_rate_down:
friendly_name: "DSL Transmission rate DOWN"
entity_id: sensor.dsl_transmission_rate_down
value_template: "{{ state_attr('sensor.fritz_netmonitor', 'transmission_rate_down') }}"
