After restart this integration is not recognised at all! No sensors, no error message in log.
From the command line I can call the “fritzcall” script with proper result thus the FritzBox config is ok.
Ok I realized that this is a misunderstanding about the function of this component. I thought it gives you a list of recent calls but it just shows the very last call, only with a timestamp but not the calling number. This sensor at least is now showing up after 1 day.
Has the callmonitor integration changed over the years? I am read some threads where more attributes are accessible but I only see:
Ok, so when I want a record of, say, all calls of this day I need to catch the attributes with a template sensor?. The history database does not store attributes but just values?
