Hello everybody,
I am new here and I have problems to activate the fritzbox_callmonitor. I took the the configuration template from the integration example:
But I do not get any feedback: no entities are created and no connection issues in the home-assistant.log (or is there another logfile relevant). My Home Assistant runs in a docker container - not sure if this is relevant (I am a bit lost about the differences with HassOS, Supervisor and Docker).
I never had problems with the callmonitor in FHEM.
It would be great If somebody has an hint for me!
Thanks in advance!!!
Best regards,
Markus
Could you tell me which Fritzbox and which Firmware you are using? And are you using an extra user for the authentification or the normal “admin” for the callmonmitor?
I’m having the same problem as some others and the phonebook cannot be accessed. I believe that could have something to do with the authentification or with the firmware version.
Hi Dennis,
I have a FritzBox 7590 with the last stable firmware (7.21). I created a spcial user for homeassistant and switched to login with usernam and password within the LAN. Hopefully this hint was helpful for you.
