Hi all,
I have a network problem trying to connect to my local FRITZ 7390
with
FRITZ!OS: 06.85
[homeassistant.components.sensor.fritzbox_callmonitor] Cannot connect to 169.254.1.1 on port 1012: [Errno 113]
trying with:
- platform: fritzbox_callmonitor
host: 192.168.178.1
host: 169.254.1.1
host: fritz.box
in the last case the error is
Cannot connect to fritz.box on port 1012: [Errno -2] Name does not resolve
but always the same results… no connection to the server
Home Assistant version is 0.84.6 and is running on docker.
My docker containers are:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ff1157a65644 homeassistant/raspberrypi3-homeassistant "/bin/entry.sh pytho…" 3 minutes ago Up 3 minutes homeassistant
717f56d5e396 homeassistant/armhf-addon-samba "/run.sh" 3 minutes ago Up 3 minutes addon_core_samba
b5b94ebd6cfb homeassistant/armhf-hassio-supervisor "python3 -m hassio" 2 weeks ago Up 4 minutes hassio_supervisor
Call-monitor is activated on the FB (#965) and tested with JFRITZ on my laptop on the same network.
From the host system i’m able to connect to the server with a telnet
pi@raspberrypi:~ $ telnet fritz.box 1012
Trying 192.168.178.1…
Connected to fritz.box.
Escape character is ‘^]’.
thanks in advance for the help
V.
