Hello guys, i have a issue with the setup as well. I tired it already several times with different integrations. I get no errors but no new devices as well. Do i forget something (Ím a newbie).Here my current setup:
I have a similar problem. fritzbox integration suddenly not working anymore. It worked some days but now i got the message after restart. This happened before but did also somehow go away (maybe by update…). the Error message is:
Invalid config
The following integrations and platforms could not be set up:
* fritzbox
Please check your config.
no solution yet. In case of failure fritzbox reports wrong password “Anmeldung des Benutzers xxx an der FRITZ!Box-Benutzeroberfläche von IP-Adresse xxx gescheitert (falsches Kennwort)”
I have found an issue: Homeassistant uses old credentials after restart/reboot. In my case it tries to login with a old username to fritzbox. configuration.yaml has the correct username but they are not used to log in. Is there a cache ?
for me enabling “Anmeldung mit FRITZ!Box-Benutzernamen und Kennwort” fixed the issue permanently for me. Was working without that option enabled before.
This have to be activated!
the second, deactivated, choice in this picture is the default (“Anmeldung mit dem FRITZ!Box-Kennwort”) in which you do not need a username by login, only a password.
NOW you need the username and password by login on the Fritz!Box UI (!!!)
which you create in the “Benutzer”-Tab
Show in your FitzOS under System -> Users. Here is a New User “fritzXXXX” change this name to “admin” and change from this user the password to your Router Password. Then restart homeassistant.
i switched from FritzBox 7560 to 7590.
A user is configured in the Fritz box. I’ve tested different users but this cannot be the fault. There is no login error in the fritzBox log.
Now i get an login authorization error by the integration ‘AVM FRITZ!Box: FRITZ!Box 7590
AVM FRITZ!SmartHome’.
On the contrary: The Fritz!Box Tools integration is working fine:
Configuration:
Home Assistant Core 2022.6.2
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.1
FritzOS 07.29
