Hi all,
after I enabled user and password for authentication in my FritzBox (OS 7.2), the integration is not working anymore.
2020-10-02 20:54:09 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry FRITZ!Box 7590 for fritzbox
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 228, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/fritzbox/__init__.py", line 79, in async_setup_entry
await hass.async_add_executor_job(fritz.login)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/pyfritzhome/fritzhome.py", line 118, in login
raise LoginError(self._user)
pyfritzhome.errors.LoginError: login for user="admin" failed
The reason seems to be that I now have a different username and password as before. The provided credentials in the config don’t match the stored credentials in config/.storage.
What would be the best solution? Delete and readding the integration? Or can the user/pw be changed in the core.config_entries file?
