Hi all,
I’m using the fritzbox integration.
Is it possible to toogle the state of the internet_access entity by the user? When I toggle the entity there is no reaction on fritzbox side. The button toggles on click but falls back to its previous state some seconds later. The displayed state of the entity is correct.
Is this behaviour a bug on my installation or the desired working scheme?
I’m struggeling with the same behaviour. Most of the time I use the toggle button on the more info page and try it until the last changed time restarts.
If you use the scheduler integration to switch internet access for fritz box entities it is working all the time.
Which FritzBox are you using? It happens on my 7590 but I’m switching to a 5590 as soon as my fibre connection is finally running.
