Fritzdect login fails after a while
Hi guys,
I moved yesterday from fhem to home assistant and I really like the UI and stuff. I was successful in setting up and adding my hardware to HA (mostly HUE, Fritzbox, Bravia and an AVR).
On the Fritzbox part, I’m using components:
  • fritzdect
  • fritz
  • fritzbox_callmonitor
  • fritzbox_netmonitor
All components are using the same credentials (username/password) and after my first setup yesterday, all where working without any issues. Today in the morning, I noticed that for some reason, fritzdect was no longer able to login - although nothing was changed on my fritzbox and in the configurations over the night.
The other components are still working fine - again: using the same credentials and host. Is this some kind of a bug?
Not using any Fritz-components, but as a general question: did you have a look at the HASS logs? It usually gives some hints on what the problem might be.
the log just says that login failed. Again: nothing changed and other fritz services are still running with the same credentials. It seems, like after a while, the password was corrupted in the hass database or something for fritzdect only.
I have the same problem. After some time and a restart of Home Assistant it fails to login. The configuration didn’t change. An additional restart does not help, I have to comment out the switch section for the fritzdect platform, do a restart, then remove the # and do another restart. Then it works again for a while.
Home Assistant is version 0.54.0. My Fritzbox is a 7390 with FritzOS 6.83.
This is the error message:
2017-10-05 09:13:18 ERROR (Thread-9) [homeassistant.components.switch.fritzdect] Login to Fritz!Box failed
The same error for me here:
Using Fritz Router type 7490, OS 06.93
Working components:
  • netmonitor
  • callmonitor
Running components on latest version 0.63.2 of HA (hasbian basis)
The only error is doing the fritzdect component telling me
ERROR (Thread-18) [homeassistant.components.switch.fritzdect] Login to Fritz!Box failed
INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: message=Login to Fritz!Box failed, source=components/switch/fritzdect.py, exception=, level=ERROR, timestamp=1518786891.78179>
I added a user to my Router, having privileges on “smart home” objects, as this failed i added complete acess for testing, but error stays the same.
Anyone any ideas?
Thanks in advance
/Ralf
Now homeassistant.components.switch.fritzdect is spamming my logfile every 5-10 seconds:
ERROR (SyncWorker_19) [homeassistant.components.switch.fritzdect] Fritz!Box query failed, triggering relogin
which is strage since everything is working related to fritzdect.
Is there a solution?
Since this week the problem has unfortunately also appeared for me.
After a restart, the AVM FRITZ! Box integration unfortunately no longer worked. The error message was a faulty login for me too.
After deleting the integration and adding it again via the HA GUI, everything worked again. After a restart, however, the error message came back.
Has anyone been able to fix the problem so far?
