From and To in Node-Red
There is a node for trigger that only trigger when this type of event happen?
platform: state
entity_id: person.me
to: home
This example, it triggers only when it goes to HOME, and not any state else.
Thank you for your attention in advance.
trigger: state node
But this node trigger with every event.
I want one to trigger just when:
Work > Home
not
Work > not_home > home
Where can i find this tab?
it’s in the trigger: state node
Where? Lol
that’s the events: state node
Ahhh, ok! Thanks!
btw is your person state really turns from work directly to home? just asking because if work location is distant from home it will trigger states as follows: work - not home - home
Then the methods above will not work
Its just an example, i just don’t want to Work > not_home trigger something, and this fix my problem!
Now it will just trigger when:
Not_home > Work
or
Home > not_home
