From HA trigger alarm lights on fibaro eye motion sensor
I would like to create alarm blinking on Fibaro Eye motion sensors if something triggers. Is it possible to create automation/scene to activate blinking(or just turn lights on) on Eye motion sensors from HA? For example if door sensor is activated… I have zwave devices connected to HA through HC3. Any suggestion is welcome.
No, there are many possibilities in the internal configuration of the device for the behavior of the LED light, but all of them are based on internal triggers on the device itself.
There is no possibility to send a command to the LED from outside.
Thank you for quick reply. So no use of eye sensors for alarm blinking… will have to buy some new lights just for that :frowning:
