From: 'home' / to: 'not_home' -> As trigger if other zones exist?
Hi, i noticed that my automation trigger for device.tracker:
  to: 'home'
or:
 to: 'not_home'
do not fire when i’m in another pre-defined zone. I was under the impression that “not_home” is for any state/zone which is NOT home. I just tested with a GPS spoofer, and “not_home” only triggers when i’m away => not in another pre-defined zone. Is this correct behaviour?
In this case, I guess its better to limit the automation with a condition? ie.:
instead of:
to: 'not_home'
I’d just do:
condition:
  condition: template
  value_template: "{% if not is_state('trigger.to_state.state', 'home') %}true{% endif %}"
You can use just from: or to: if you want
So:
will be fine
True… i dont even need the extra condition, as the state can only change to home if its not home… was thinking way to complicated again :wink:
so instead of:
to: 'not_home'
just:
Thanks :slight_smile:
