rodolfocm
(Rod CM)
1
I have the following sensors working till yesterday but then it starts to show as “Unknown”.
- sensors:
peso_rodolfo:
friendly_name: "Peso Rodolfo"
value_template: >-
{% set weight = states('sensor.mi_body_composition_scale_9c1e_mass') | float %}
{% if weight >= 69 %}
{{ states("sensor.mi_body_composition_scale_9c1e_mass") }}
{% else %}
{{ states("sensor.peso_rodolfo") }}
{% endif %}
unique_id: sensor_peso_rodolfo
unit_of_measurement: "kg"
icon_template: mdi:weight-kilogram
- sensors:
impedancia_rodolfo:
friendly_name: "Impedancia Rodolfo"
value_template: >-
{{ states("sensor.mi_body_composition_scale_9c1e_impedance") }}
{% else %}
{{ states("sensor.impedancia_rodolfo") }}
{% endif %}
unique_id: sensor_impedancia_rodolfo
unit_of_measurement: "ohm"
icon_template: mdi:omega
sensor.mi_body* are working fine
They are configured in template.yaml. And in my configuration.yaml has
template: !include templates.yaml
This type of configuration is not allowed anymore?
Do I need to change to
Template - Home Assistant (home-assistant.io) ?
I’ve read that but I’not sure how to set “state” and “state_class”.
will value_template be state?
123
(Taras)
2
Your sensors are defined using legacy configuration. Yet you put them under the template:
key which is exclusively for modern configuration.
Legacy sensor configuration must be defined under the sensor:
key, not the template:
key.
Reference
Template integration
If you have this line in your configuration.yaml
file:
sensor: !include sensors.yaml
Then you can put this in the sensors.yaml
file:
sensors:
peso_rodolfo:
value_template: >-
{% else %}
{% endif %}
impedancia_rodolfo:
value_template: >-
{% else %}
{% endif %}
Alternately, you can convert your sensor’s configuration from legacy to modern format and put it in templates.yaml
- sensor:
- name: "Peso Rodolfo"
state: >-
{% else %}
{{ this.state }}
{% endif %}
icon: mdi:weight-kilogram
- name: "Impedancia Rodolfo"
state: >-
{% else %}
{{ this.state }}
{% endif %}
icon: mdi:omega
rodolfocm
(Rod CM)
3
Thanks! That worked.
I decided to change to modern to avoid future problems.
