From 'old' mqtt config to new config
Yesterday I upgraded to 2022.9.0 and after the restart, I got 3 warninigs that mqtt config (for my mqtt switches, sensors and binary sensors) would no longer work after … (around end of the year I think).
That old config looked like this eg (switch)
configuartion.yaml
switch: !include_dir_merge_list switches/
in switches/ I have a file eg alarm.yaml with content like this
  - platform: mqtt
    unique_id: alarm_state
    state_topic: "engrie111/alarmtrigger/data/alarm"
    command_topic: "engrie111/alarmtrigger/command"
    payload_on: "Alarm=ON"
    payload_off: "Alarm=OFF"
    state_on: "ON"
    state_off: "OFF"
    qos: 1
    retain: false
So, based on what I found I reconfiged like this
configuration.yaml
mqtt: !include_dir_merge_list mqtt/
in mqtt/ I have a file alarm.yaml with content
  switch:
    - name: "Alarm State"
      state_on: "ON"
      state_off: "OFF"
      qos: 1
      retain: false
Note that I removed the alarm.yaml from the siwtches dir.
Running ‘check configuration’ gives me a valid config. But after restart, the entity in no longer available.
Checking/listening to the topic using the MQTT integration GUI also works fine.
In the list of entities, the entity switch.alarm_state sits under integration mqtt but, as said, no longer available while hoovering over the “red counter-clock rotation + exclamation mark”- symbol, "Restored’ is shown.
Note: beside the alarm.yaml, I have several other yaml files in mqtt/ that contain sensor and/or switch and/or binary_sensor mqtt settings. Is that a problem?
What am I missing or overseeing to get the entity active again?
Regards
Marc
This is a list:
- something
- something else
- another thing
This is not a list:
  switch:
      unique_id: alarm_state etc...
Try merge_named https://www.home-assistant.io/docs/configuration/splitting_configuration/#example-include_dir_merge_named
Or -
mqtt:
  sensor: !include_dir_merge_list cfg/_component/mqtt/sensor/
  binary_sensor: !include_dir_merge_list cfg/_component/mqtt/binary_sensor/
  switch: !include_dir_merge_list cfg/_component/mqtt/switch/
is the way I do it, because I have multiple files for each
Thx. I see where I missed it. But I shoose for the way andrw Jones did it as that matches the way I have set-up my HA. Lesson learned :wink:
Thx. Indeed, that solved the problem. It was an easy fix.
