I’ve been running HA over Raspberry Pi 3+ (more or less) flalessly. I would love to move my setup to a new larger machine running Ubuntu Server LTS, as to be able to run a Roon Server from that same machine as well.
Which is the best (I should say easiest, maybe) way to move from Raspberry Pi 3+ to Linux?? I would really appreciate your input.
If you run Ubuntu, you only have 2 choices : in a venv (HA Core) or in Docker (HA Container). HA Supervised is not supported on Ubuntu, and will be in an unhealthy state in no time.
But a quick google shows roon server runs fine on Debian, in which case you run supervised too.
I’d say that Home Assistant Operating System VM is the better one, its a Supervised version so has the most amount of options.
It’s easy to create VM snapshots before upgrades or big changes. Also if you backup the .vdi or .vmdk file it’s easy to migrate or even quickly move to another hardware in case of DR.
I ran a VirtualBox VM on an Ubuntu Server (could be a Debian as well). I set it up to start the VM on start up, works like a charm and shares box with several other vm servers.
You’re assuming that’s easy. Given how often people get this wrong, or ignore the requirements and get into trouble, it is continually demonstrated to be far from easy.
