Hi
After trying out ZHA with my exiting Xiaomi sensors for temperature and humidity, I find the update interval is much lower in ZHA and the accuracy therefor is reduced.
I was trying to remove the device from ZHA and add it back to the xiaomi hub - but not the hub seems to ignore the sensor when I do the pairing process and after I restart home-assistant the device is listed back in ZHA.
not sure if ZHA needs to properly “release” the sensor for Xiaomi Hub to be able to pair with it - or why this is even a problem to switch back and forth (I may be doing something wrong?)
anyway - if you can explain how I can switch back to Xiaomi hub OR increase the scan interval on the sensor from ZHA settings - that would be awesome.
