Hi all,
My new setup is:
- Inverter:Fronius Verto Plus
- Battery:Fronius Reserva
The Fronius integration works fine with only one problem.
The feed-in-charge entity appears not to be working. Here is the exact situation as it appears.
Using only the verto web interface I can only trigger “forced charge” state by the time schedule. If that state is not triggered by the schedule the battery is never charged by the grid - if there is no surplus from the panels it is not charged.
turning on the modbus control appears to lock the battery in whichever state it is at this moment (if it is force charging it keeps on doing this regardless of the time schedule)
The battery_grid_charging entity has no effect on the situation in any case. Turning it on or off doesn’t change anything as far as I can tell. Charge power limiting works.
Am I missing something?
Anyone with this setup able to control a charge from the grid through home assistant?
Any help will be appreciated at the moment the only (obviously insane) way I am able to trigger a charge from the grid is - stop modbus contro - turn on time schedule in the web interface - turn back modbus control. then this needs to be repeated when I want to turn off the force charge.
