my question isn’t about home-assistant implementation, but generally modbus oriented.
I’m searching for modbus register numbers for controlling dynamic power reduction mechanism.
In float model I found some registers.
I thing service modifications via browser aren’t implemented in modbus.
It’s possible to only set a % amount of max avalliable power with enable/disable modbus telegrams ?
Export limit protection set limit values haven’t equivalent as modbus telegramms or ?
This is a automation mechanism, that computed maximum inverter power dynamically according Fronius meter “feeding into grid” value. Above method needs to compute in external algorithm the necessary max power.
Thank’s for help.
so i want to limit my Battery Output to the minimum when the dynumic power price is at low cost.
what i found out to set via Modbus to the register 40309 (fronius symo hybrid)
StorCtl_Mod = 0 (Standart) ; 1 only discharge allowed ; 2 only charging allowed
