Updated Home Assistant via hass.io this morning to 0.60.1. All was well and then rebooted my Pi3 and now only get the following from hassio.
18-01-08 23:27:38 INFO (SyncWorker_6) [hassio.docker.interface] Restart homeassistant/raspberrypi3-homeassistant
18-01-08 23:32:38 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-01-08 23:37:38 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-01-08 23:37:38 INFO (SyncWorker_13) [hassio.docker.interface] Restart homeassistant/raspberrypi3-homeassistant
18-01-08 23:42:38 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-01-08 23:47:38 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-01-08 23:47:38 INFO (SyncWorker_1) [hassio.docker.interface] Restart homeassistant/raspberrypi3-homeassistant
Following the Home Assistant logs everything looks ok and loading as normal. But the web service never appears to load. Not sure what my next step would be. Have tried multiple host / supervisor and homeassistant restarts with no change.
