I have an issue that front end is showing a number of ‘NOT FOUND’ status icons. How do I clean these out?
Many thanks.
How are you managing your frontend? lovelace GUI, Lovelace yaml, lovelace auto generated, states UI?
Lovelace auto generation I would say since I haven’t modified a YAML file for the interface.
That brings up more questions.
Have you ever had a frontend before now? Did you update from a HA that used the states UI or did you go right into using lovelace as the default?
And I guess the real question is why are those icons there in the first place? And why are they now saying “not found”?
Did you change a configuration to cause them to go away or did you update and for some reason the entity_id changed and the badge now refers to a entity_id that is different than it was expecting?
If you have been using the default auto-generated Lovelace, you can edit to remove them but you then manage the UI.
When looking at Overview, in the upper right menu select “Configure UI” IF the That editor is not intuitive, you can then select the upper right menu to edit the raw configuration file.
Got it, thanks. I’ve never configured the front end & I will now.
