I am the creator of the Ihc Viewer custom component:
In version 0.114.x it was working fine, but in version 0.115.0 the panel does not load (A messagebox saying unable to load).
The component use the async_register_built_in_panel to load the panel. Some views are registered with http.register_view and some static files with http.register_static_path. The views and static files are working because i can access these directly.
Anybody that can tell me what has changed in 0.0115.0 , so i can make the panel load again?
After looking further into this I have found that HTML support has been removed for the panels, so now you can only use js modules? The current panel is done using polymer 2, so I assume i have to change that to polymer 3 or LitELement ? (I am not at all a polymer expert)
Another question: I don’t see this change it in the release notes, but i guess these are more for the “regular” user. Are there any list of that kind of development changes - specially when there are breaking changes?
I still have a 0.114.4 running and i don’t see it in the log. Maybe because i have loglevel set to “warning”. I did not see it in the 0.112 “bearking changes” (i guess i did not associate the custom panel with the frontend.async_register_built_in_panel function). I will have to read the breaking changes more carefully in the future.
