Hi there im having a similar issue on tha last 2 versions of home assistant (0.70 and 0.71) my configuration tab not working and some side menu icons missing but when a I install 0.69.1 all working good im using hassbian in armbian OS in orange pi with virtual environment installation ! ANy idea what is heapening ?
.70 introduced changes to the front end
any custom UI’s need to be updated, Floorplan, Custome alarm, Custom UI etc.
If you are using Chrome, try this:
- Open the developer tools (right click and choose “Inspect”, or press ctrl+shift+i)
- Press “>>” at the top and select “Application”
- Choose “Clear storage” from the list to the left (the bin icon)
- Click the “Clear site data” button
- Refresh the page
This worked for me after upgrading from 0.68 to 0.71.
I also updated custom_ui.
There’s probably simmilar methods for other browsers.
hello thanks is not a browser problerm i did that and didnd´t work I also used diferente browser and diferente computer!
Did u update the custom alarm component as i see it listed in screenshot
Until u upgrade any compnents that use ant custom UI, you will get these errors
