Hi!
I have two ESP32 controllers. Entities defined and running. One has relay_1_1, other esp has relay_1_2 etc.
I made new dashboard just to be sure.
One view has relay_1_1 as entities card (and all other sensors from esp1)
Now I want the same view for esp2 so I copy this view section in raw config editor and change the name of the view and relay_1_1 edited to be relay_1_2. the same with all other sensors.
After saving - new view page appears, but instead of relay_1_2 it responds to relay_1_1. and indeed each individual entities card displays relay_1_1 not relay_1_2 as can be seen in raw config editor.
If I then manually change it to relay_1_2 (through UI because yaml seems to be corect) then both views take the change and now both are relay_1_2
So… how do I copy view configuration throughout multiple homeassistant instances or dashbords using yaml?
Home Assistant Core 2022.6.6
Home Assistant Supervisor 2022.07.0
Home Assistant OS 8.1
