Thanks. The problem is I can’t get past yarn install since it can’t find it. So I have nothing to remove… Can I somehow remove it from the scripts under home-assistant-polymer ? Which files should I edit to do this?
I get: “error This module isn’t specified in a manifest.”.
Nothing helps…
I’m not sure if anyone has recently managed to setup a frontend dev environment… I’d love to know how or download an image that works.
Feeling lost & frustrated.
Is there a way I could take the open dev files and put on a duplicate prod environment to play around with the markup, etc? That’s all I want to do and later create pull requests on some features I think are needed.
I removed all zopfli references from all files (except JS) and got past yarn installation. But now running the script/develop fails since there’s no gulp-zopfli…
catch 22
@andrey - maybe you can undo what you did in “switch to Zopfli compression (#744)”? I’m not yet familiar with the code and don’t want to kill anything.
