Frontend Development Setup Probems
Trying to setup a development environment to make some changes to the frontend.
I am using the configured docker containers for both the core and frontend git repositories.
Followed the instructions for setting up: Setup
When I add the following to configuration.yaml and restart:
frontend:
 development_repo:/workspaces/frontend/
It always comes up in safe mode.
In the log file I get:
2021-08-11 00:27:35 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds
2021-08-11 00:27:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: frontend, logbook, map, my
2021-08-11 00:27:35 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
Whether there is a space after development_repo:?
I am also facing problem with dev environment , i ran the core and did everything mentioned in the document , but is saying
" Detected that frontend did not load. Activating recovery mode "
Can anybody help me in this ?
