I’m trying to start frontend development on a Windows 7 machine. All installation steps works fine but two things won’t work.
1.) Running npm run js_dev won’t work
error Windows_NT 6.1.7601
error argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "run" "js_dev"
error node v6.9.5
error npm v3.10.10
error code ELIFECYCLE
error [email protected] js_dev: `script/gen-service-worker.js && npm run watch_ru_all`
error Exit status 1
error Failed at the [email protected] js_dev script 'script/gen-service-worker.js && npm run watch_ru_all'.
error Make sure you have the latest version of node.js and npm installed.
error If you do, this is most likely a problem with the home-assistant-polymer package,
error not with npm itself.
error Tell the author that this fails on your system:
error script/gen-service-worker.js && npm run watch_ru_all
error You can get information on how to open an issue for this project with:
error npm bugs home-assistant-polymer
error Or if that isn't available, you can get their info via:
error npm owner ls home-assistant-polymer
error There is likely additional logging output above.
verbose exit [ 1, true ]
2.) script/build_frontend does’nt work either
I hope somebody can help me out.
Thx
