First time I’ve had any major dramas in an upgrade, but basically my map, config and logbook panels won’t work in 0.58
errors:
2017-11-19 17:36:26 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 179, in _step
result = coro.send(None)
File "/home/hass/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 343, in finalize_panel
yield from panel.async_finalize(hass, repo_path)
File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 210, in coro
res = func(*args, **kw)
File "/home/hass/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 182, in async_finalize
hass_frontend.FINGERPRINTS[self.component_name])
KeyError: 'dev-event'
KeyError: 'dev-mqtt'
KeyError: 'dev-info'
KeyError: 'kiosk'
KeyError: 'dev-template'
KeyError: 'dev-service'
KeyError: 'dev-state'
2017-11-19 17:36:29 ERROR (MainThread) [homeassistant.setup] Error during setup of component map
File "/home/hass/lib/python3.6/site-packages/homeassistant/setup.py", line 190, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/home/hass/lib/python3.6/site-packages/homeassistant/components/map.py", line 16, in async_setup
'map', 'map', 'mdi:account-location')
File "/home/hass/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 246, in async_register_built_in_panel
yield from panel.async_register(hass)
File "/home/hass/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 127, in async_register
yield from hass.data[DATA_FINALIZE_PANEL](self)
KeyError: 'map'
2017-11-19 17:36:30 ERROR (MainThread) [homeassistant.setup] Error during setup of component config
File "/home/hass/lib/python3.6/site-packages/homeassistant/components/config/__init__.py", line 24, in async_setup
'config', 'config', 'mdi:settings')
KeyError: 'config'
2017-11-19 17:36:31 ERROR (MainThread) [homeassistant.setup] Error during setup of component logbook
File "/home/hass/lib/python3.6/site-packages/homeassistant/setup.py", line 193, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/local/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/local/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/home/hass/lib/python3.6/site-packages/homeassistant/components/logbook.py", line 104, in setup
'logbook', 'logbook', 'mdi:format-list-bulleted-type')
KeyError: 'logbook'
I initially tried the new javascript:
frontend option, and have since removed it, but other than that no change to config. Have had to rollback for now.
Anyone have any ideas?
