I was able to display the hassio.local:8123 web page on both my older iPhone4s and iPad3 prior to upgrading Home Assistant to v0.79.0
Has something changed in the new version that would prevent me using these older devices?
TIA
Ian
TIA
Ian
I’m having the same issue, both in the ios app, and the browser. - any luck with this?
Sorry, no.
I upgraded to 0.79.3 from 76.2 and I am seeing none of my switches/sensors only camera and some MQTT sensors but nothing else.
Any help or do i have to go back to 0.76.2.
Same issue on iOS9 here.
Looks like it was reported to the issue tracker a few days ago, and sounds like they have found the culprit, so hopefully when 0.80.0 hits we should be good (or 0.79.4? Not sure how often the pull the latest front end into the build, since they are seperate repos).
Cameron, I suspect yours is a different issue (at least, it doesn’t look like the one I had, which is the same as the one in the issue I linked).
EDIT: Just switched to 0.80.0b4, and can confirm my iPad works fine again. Just hope the beta doesn’t break anything I need.
Yes it was. Thanks
