I upgraded to the latest version a few days ago… tonight I came home and the frontend will not load (error message is Safari could not open the page because the server stopped responding) and I’ve searched the log file and there are no errors. What is the next step to diagnosis this problem?
Do you have "frontend: " in your config?
Yes… I had a working v0.22 system as of this past Saturday. I didn’t use the frontend again until last night when I learned it was not working
some component can be causing problems, perhaps you can begin with a simple config file and add components until the problem appears.
Well I guess I just needed to post on this site Woke up this morning and the frontend is loading
