Hallo, I got the following errors in home-assistant.log after updating form 0.114.4 to 0.115.1 by pip3 install:
2021-05-23 10:51:25 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Unable to import component: libopenjp2.so.7: cannot open shared object file: No such file or directory
2021-05-23 10:51:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2021-05-23 10:51:25 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2021-05-23 10:51:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
2021-05-23 10:51:25 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2021-05-23 10:51:25 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2021-05-23 10:51:25 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2021-05-23 10:51:26 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2021-05-23 10:51:26 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
2021-05-23 10:51:26 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of panel_iframe. Setup failed for dependencies: frontend
2021-05-23 10:51:26 ERROR (MainThread) [homeassistant.setup] Setup failed for panel_iframe: Could not set up all dependencies.
2021-05-23 10:51:26 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
2021-05-23 10:51:26 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2021-05-23 10:51:34 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
Installation of libopenjp2-7 did not help. I did not find any clue in the breaking changes for 0.115.
What could be the problem?
