I’m running Home Assistant Core. When I upgrade via pip3 install --upgrade homeassistant
it reports that homeassistant-2021.1.5 was successfully installed. However, the frontend Info page shows version 2021.1.1. As a result, I can’t log in remotely via Nabu Casa, and I’m getting warnings about running an unsecure version.
Here’s what I’ve tried (with rebooting the server between each step)
- Updating the raspberry pi generally via
sudo apt update, sudo apt full-upgrade
- Uninstalling HACS
- Deleting everything in my configuration.yaml except
default_config:
- running
pip3 install --force-reinstall homeassistant
The only interesting thing in the log is this message:
2021-01-24 19:01:33 WARNING (MainThread) [homeassistant.bootstrap] Support for the running Python version 3.7.3 is deprecated and will be removed in the first release after December 7, 2020. Please upgrade Python to 3.8.0 or higher.
But it seems unlikely to be the issue?
