I know its only a very minor, unimportant issue, but just thought I’d make you guys aware.
As you can see I have a dark theme as i’m quite sensitive to bright lights.
After the update to version 0.58 I found that this page, and this page only, does not seem to apply the dark background colour i have setup in the theme.
Hopefully its a quick and easy fix.
Cheers, Brian.
Also, in the default theme, the word “states” and “logout” are missing.
I have just noticed the same thing on mine. I’ve refreshed, restarted & rebooted a few times now.
The text has seemingly come back but the ‘configuration’ background is still not using the theme colours.
You might want to give that a go first @jeremyowens , hope it helps you.
I noticed the same.
