Frontend Unavailable
since this morning the Frontend is unavailable.
Here’s the log:
2018-12-18 11:17:32 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
2018-12-18 11:17:32 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
2018-12-18 11:17:32 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2018-12-18 11:17:32 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2018-12-18 11:17:32 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger
2018-12-18 11:17:32 INFO (MainThread) [homeassistant.setup] Setting up logger
/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py:847: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: Advanced Usage - urllib3 2.2.1 documentation
InsecureRequestWarning)
I searched around but there’s no reverence in the forum.
What did you find? My system started doing this in the last few days under 0.92.2.
Issue came and then disappear. Don’t know why
